This procedure only applies to a switch with boundary-node abilities.About this task
Display routing information for Anycast IP Gateway interfaces on BEBs.
- Select Anycast Gateway Remote.
- Select ISID.
ISID Field Descriptions
Use the data in the following table to use the ISID tab.
Name | Description |
L2vsn Isid |
Displays the Layer 2 VSN I-SID. |
Adv Sys Id |
Displays the IS-IS system ID of the advertising node. |
Address Type | Displays the address type. Currently, only IPv4 is supported. |
Address |
Displays the IPv4 gateway address. |
L3vsn Isid |
Displays the Layer 3 VSN I-SID. |
Mac |
Displays the gateway MAC. |
Path Cost |
Displays the SPB path cost to the next hop. |
Add Metric |
Displays the SPB cost advertised by the Multi-area SPB designated boundary node. |
Next-Hop BMAC |
Displays the BMAC of the next hop. |
Rtr HostName |
Displays the host name of the advertising node. |
Is Gw Node | Displays if the advertising node is the installed Anycast IP Gateway node. |
